Digital Speedometer - Change from KPH to MPH?
24 Jun 2007
My dad has a C Class Mercedes Estate (C220 - Year 2007) pretty basic model. Not many fancy extras. It comes with a Digital Speedometer. The Analogue Speedometer shows MPH only and the Digital shows KPH only. Is there any way to get the Digital one to show MPH seeing as we don't really use KPH at all in the UK? Tried looking in the Owners Manual but no luck.
You can do this via the menu on all Mercs - accessible using the buttons on the sterring wheel.
Hmmm don't have a W204 to hand here to talk you through the sequence, I think it's up arrow until you get to setting them select display and IIRC it's in the option.
JUST REMEMEBERED, does the car have a multi function steering wheel? a 12 button one?
If it doesn't then it's not possible.
Certainly on the W220 its done as per Mazs instructions. You go to the settings menu option, then up/down to scroll through all of the car settings. Not much help probably, but if you cant find a way to do it like this then i would say you probably cant do it at all.
