digital tv for pc.
28 Feb 2013
Leeds
Hi. Sorry if this is the wrong place. I couldnt anywere to put it.
I am wanting to buy dvb for my pc. But i want one with a remote and one that i can record , pause ect ect.
Basicly like sky or virgin.
Can anyone recommend one?
thank you.
Jonnyp
Buy any DVB-T card or USB adaptor and use Windows Media Centre as the software. Most bundled software is poor.
I've got a couple of Chinese, no-name DVB-T USB sticks in my HTPC. They are fine.
/slight hijack
i presume you install the bare drivers and then do everything else through WMC? do you then need a remote that is compatible with WMC?
That's what I used to with a Hauppage Dual DVB-T PCI card. I used the official Microsoft Media Centre remote which was one of the nicest you could get (light up buttons + came with IR sender to control set top box etc) but think it has been discontinued for a while.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-028-CP
would fit the bill though
