- 14 Sep 2010
- Port Talbot - Wales
Could using a fan controller make my case fan get less voltage than it would recieve if it were plugged into a mobo header or directly into a molex?
I only ask as my front fan LED seem to be really dim - they get REALLY dim when I turn the fan controller down (as you would expect...) but I was wondering if maybe it could be getting less than it's full 12v
Any ideas? (really can't be bothered taking the side off and moving the wiring to check as the fan wire is pretty well hiddin in my "loom"(mess) lol
Thanks in advance...
