DIMM.2 nvme
11 Jul 2003
Telford//west mids
Should I use this to install my main operating system on my pc or use the motherboards slot, it's on the asus z790 apex, I'm not sure what to do as I've never had one of these before.
Thanks
It's just Asus rerouting PCIe lanes from the usual bottom expansion slot to somewhere with more room.
Had a look at the manual but it doesn't state if it's using lanes from the CPU or chipset. For the M.2 slots already on the board, the top is CPU controlled while the bottom is chipset controlled. I'm going to take a wild guess that seeing both x16 slots and the top M.2 slot uses all 20 CPU lanes, that the DIMM.2 slot is chipset controlled, therefore I would be tempted to use the top M.2 slot for the OS already there.
