- 26 Aug 2008
Hi everyone
iv got Virgin cable with wireless being distributed through a cheap edimax 6324nl. I have used a couple of belkin powerlines for a few years and they have been brilliant for laptops upstairs, but recently we purchased a couple of tablets and have found the wireless capabilities of the edimax very limiting. signal strength in the room above the router is great but going through walls is a bit of a problem.
My question is can you recommend some good wireless routers that are easy to set up (plus i dont mind purchasing wireless extenders for upstairs).
I notice there is a substantial price differential between wireless routers on oc website - is it worth spending say £100-£150 on a router and extender or do diminishing returns set in?
Cheers
Ian
The other option would be to purchase one of the powerline kits which also extend the wireless signal.
Cheers
Ian
