Ok, so whilst my new cable connection is great, its only great when its wired or I'm right beside the Superhub.
I got a cheap DIR-615 off eBay and flashed it with DD-WRT, but even when I setup the Superhub in Modem Mode, and configure the DIR-615 for wireless, the signal is still rubbish. I guess it must be due to my new flat, the walls just aren't letting anything through.
Anyway, I was wondering if its possible to set it up so that the Superhub produces a wireless signal, but also the DIR-615? The Superhub will be in the living room for the 360 and laptops when we are in there, and the DIR-615 will be in my room in the middle of the flat, so that I and my housemate can get wireless on the laptops and phones in our rooms.
Can you set it up so that both routers give a wireless signal, i.e. as a repeater or wireless bridge (is there a difference?)?
I'm rubbish at setting these things up, so if anyone could give a step-by-step guide, that would be brilliant.
