Hi Guys,
My current router (a D-Link DGL-4300) has just given up the ghost.
I bought it for the oversized NAT table so it could handle torrents better but it had started struggling and the wireless would fail every now and then, but it now just doesnt turn on.
Current favourites are the following:
Netgear WNDR3700 - http://www.netgear.com/Products/RoutersandGateways/WirelessNRoutersandGateways/WNDR3700.aspx
DIR-855 Xtreme N Duo - http://www.dlink.com/products/?pid=548
Features needed:
I like that you can have a second wireless network on the Netgear one.
Budget wise £150 max would be good.
Any thoughts on which would be best or if there is a better one out there?
Cheers,
Paul
Features needed:
- Gigabit (ideally 6+ ports but have another router to use as a switch so atleast 4 ports)
- Decent sized NAT table to cope with BitTorrent
- Decent ish wireless (nothing in particular as it's only 54G devices I have, greater range would be good)
- Would be good to be able to connect a USB printer
Cheers,
Paul
