http://www.direct2drive.com/
After seeing numerous adverts for this I decided to check it out. According to them you pay for the game and it's your's to do what you want with it. You can re-download it as many times as you need once you have paid for it, which is kind of cool, and you can save it to a dvd/cd, again kind of cool. The one major problem is patches and expansions. You have to use patches / expansions supplied by them, no other ones will work.
I can see this being a reasonably good idea but I'm not sure on the whole having to use their patches. On the other hand the prices are in $ so it would probably work out cheaper than buying in shops.
Has anyone used this before or does it look like too much hassle?
Dons, if this a bit shady apologies, but from the looks of it they are owned by ign/Gamespy so I'm pretty sure it's legit.
