I have two Vista x64 PCs next to each other. Both connect to the wireless network for internet access. But of course large file transfers are painfully slow. I've plugged a network cable between the two, and it shows up in the connection centre on each machine as an unidentified public network. Is it possible to have file transfers done directly using the cable, if so, how ?
thanks
thanks
I'd rather not have to do that though - the priorites sounds lime the fix, I'll take a look
