Direct PC>PC connection in addition to switch connection
16 Nov 2007
Hi
Would the following be possible and also introduce 10Gb transfer speeds?
PC A connected to central switch (1Gb)
PC B connected to the same central switch
File transfers occur at 1Gb bandwidth
Assuming both PCs have additional 10Gb NICs in addition to the above connections
PC A is now also connected to PC B via 10Gb NICs on each PC
Will file transfers now occur at 10Gb? Do the PCs auto-sense a higher bandwidth connection and choose the best path? I presume the 10Gb NICs need to be configured on a different subnet to avoid a network loop?
I know there's no consumer kit available to saturate 10Gb, just thinking of maximising SSD > SSD transfer.
Thank you
Mike
Thanks. So just to confirm, the direct connection is in addition to the general connection to the master network? For clarity I need the master connection (1Gb) for general network and WAN access with the additional 10Gb direct connection for local file transfer.
Thank you
