- 19 Oct 2008
Has anyone else had Direct X 10 related problems recently?
I had this a few weeks back and did a reinstall of the OS. I thought I would try it again.
Basically I can play Direct X 11 games fine, well, at least FarCry 3 still works anyway!
I installed FarCry2 via Steam and played that in DirectX10 mode and all fine. Well apart from bouncing people but I don't think that is related to the problem I'm having. It did the DirectX install thing when invoking the game for the first time.
I then installed Stalker Clear Sky. That did the DirectX install thing when invoking the game for the first time. Everything looks fine. I go to the menu and select my resolution (2560*1440) and enable the direct x 10.1 option. When I click "Use" the resolution changes. I then exit the game as was previous requested (as this is required to enable Direct X10). WHen I invoke the game again all I get is a black screen with a white cursor.
I then go back and try FarCry 2 again and after the walking animaiton at the beginning the game basically just returns back to desktop with no errors displayed.
I haven't check the event logs just yet but wondering if anyone else experienced this and how to resolve? It seems Direct X related, as if the auto-direct x update that happens when you run Clear Sky for the first time buggers things up!.
Last time it happened (before I did the OS reinstall) I did manage to get back into ClearSky again by changing the config file to not use DirectX10. However that doesn't help Farcry 2 and I dont want to run in DIrectX9 mode!
And yes I have tried rebooting
Note: I didn't have issues in the past with old graphics card (Gtx670). Now using Gtx690 and latest beta drivers but before reinstall of OS I was using the latest non-beta drivers and had the same problem. Have tried disabling Sli in case it was related to DirectX10 and that but same prob.
