Direct X problems - help!
Ole
Ole
15 Apr 2004
When I try to start Fallout 3 and Football Manager 2009 I get the following error:
This application has failed to start because d3dx9_37.dll was not found. Re-installing the application may fix this problem.
So I tried to reinstall DirectX and I get an error and it won't install. The error log says as follows:
Code:
[11/10/08 20:59:32] module: dsetup32(Oct 22 2007), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
DirectXUpdateInstallPlugIn() failed.
and
Code:
11/10/08 20:58:43: dsetup32: === SetupForDirectX() start ===
11/10/08 20:58:43: dsetup32: Oct 22 2007 03:20:38
11/10/08 20:58:43: dsetup32: SetupForDirectX(): query dxsetup command: result = 2.
11/10/08 20:58:43: dsetup32: DXSetupCommand = 0.
11/10/08 20:58:43: DXWSetup: DSetupCallback(): Phase = 0, Steps = 0
11/10/08 20:58:43: dsetup32: Installing on Windows 6.0.6001
11/10/08 20:58:43: dsetup32: DirectXSetupIsJapanese == 0
11/10/08 20:58:43: dsetup32: DirectXSetupIsJapanNec == 0
11/10/08 20:59:31: dsetup32: IsIA64(): not IA64.
11/10/08 20:59:31: dsetup32: CLR version number = 2.0.50727
11/10/08 20:59:31: dsetup32: DXCheckTrust(): C:\Windows\system32\DirectX\WebSetup\dxupdate.cab is trusted.
11/10/08 20:59:31: dsetup32: GetCDXUpdate(): Extracting dxupdate.dll from C:\Windows\system32\DirectX\WebSetup\dxupdate.cab.
11/10/08 20:59:31: dsetup32: Extracted file C:\Users\Oli\AppData\Local\Temp\DX58DB.tmp\dxupdate.dll from cab
11/10/08 20:59:31: dsetup32: Extracted file C:\Users\Oli\AppData\Local\Temp\DX58DB.tmp\dxupdate.inf from cab
11/10/08 20:59:31: dsetup32: Extracted file C:\Users\Oli\AppData\Local\Temp\DX58DB.tmp\dxupdate.cif from cab
11/10/08 20:59:31: dsetup32: GetCDXUpdate(): Loading dxupdate.dll in C:\Users\Oli\AppData\Local\Temp\DX58DB.tmp\.
11/10/08 20:59:31: dsetup32: DirectXSetupIsJapanese == 0
11/10/08 20:59:31: dsetup32: DirectXSetupIsJapanNec == 0
11/10/08 20:59:31: dsetup32: IsWow64(): running on Wow64.
11/10/08 20:59:32: dsetup32: CSetup::InstallPlugIn(): DirectXUpdateInstallPlugIn() failed.
11/10/08 20:59:32: DXWSetup: DSetupCallback(): Phase = 0, Steps = 0
11/10/08 20:59:32: dsetup32: start finalizing: phase: 0 - 0, total: 0 - 0
11/10/08 20:59:32: DXWSetup: DSetupCallback(): Phase = 3, Steps = 0
11/10/08 20:59:33: dsetup32: Installation ended with value -9 = Internal or unsupported error
11/10/08 20:59:37: DXWSetup: WM_APP_ENDINSTALL
11/10/08 20:59:37: DXWSetup: CDXWSetup::~CDXWSetup()
11/10/08 20:59:39: DXWSetup: CreatePropertySheet() returns -9.
11/10/08 20:59:39: DXWSetup: Deleted file C:\Windows\system32\directx\websetup\dsetup.dll.
11/10/08 20:59:39: DXWSetup: Deleted file C:\Windows\system32\directx\websetup\dsetup32.dll.
Has anyone got any ideas how to fix this so I can play these great games?
Thanks.
Have you run a dxdiag from the Start>Run?
Have you run the dxsetup.exe in the FM folder? If you can't find it search for DXSETUP.exe or if you can find it, it should be in C:\Program Files (x86)\Steam\SteamApps\common\football manager 2009\directx.
It is Program Files (x86) you want as you are running Vista x64 HP (Like me. :).
If that doesn't work then download and install this.
And since you refer to FM09 as a great game, have you patched it yet? Unrelated to your DirectX issue btw. :)
