- 20 Oct 2002
- Barnsley, UK
Hi Everyone
I wonder if someone can shed some light on a small problem.
I've just been and bought Call of Duty 2 - Modern Warefare and have some problems at keeping the game stable. After playing the game for around 20-30mins with no issues at all, all the sound is fantastic, graphics are rich and smooth. The game seems to crash to desktop, with the following error.
"Direct3DDevice:
resent Failed"
Obviously I detected this is something DirectX releated and tried all the following listed below to correct issue. Sometimes the game just crashes to windows with no error. I instantly thought this might be HEAT with the new graphics card, and went and bought 2 fans to keep the system cool. However I then noticed that I could go back into the game and play for another 30 mins, CRASH then back in for another 30 mins. If this was heat surly it wouldn't be as consistant than if I was running from a cold start.
I then started to monitor the GPU temps. Under load my GPU0, and GPU1 run at around 57-63oC which I see from other sites its pretty good. I have no other issues with the PC, no other blue screens or crashs.
Windows Event Viewer has the following information:
Log Name: Application
Source: Application Error
Date: 06/01/2010 14:44:10
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: Dyson-4
Description:
Faulting application name: iw4sp.exe, version: 0.0.0.0, time stamp: 0x4b26b24b
Faulting module name: iw4sp.exe, version: 0.0.0.0, time stamp: 0x4b26b24b
Exception code: 0xc0000005
Fault offset: 0x0027114a
Faulting process id: 0xe50
Faulting application start time: 0x01ca8edc6fb5fee0
Faulting application path: c:\program files (x86)\steam\steamapps\common\call of duty modern warfare 2\iw4sp.exe
Faulting module path: c:\program files (x86)\steam\steamapps\common\call of duty modern warfare 2\iw4sp.exe
Report Id: f2cb34b0-fad1-11de-90c1-002354076835
System Specification
Microsoft Windows 7 -Enterprise Edition (64-BIT)
AMD Phenom II X4 945 - 3.01Ghz
8.00 GB of DDR2 RAM
Gainward GeForce GTX 295 (Running Latest 195.62 WHQL Drivers)
Creative X-FI Extreme Music Edition (Running Latest Drivers)
Trouble Shooting Attempts
Fitted 2 x 120mm Fans
Uninstalled and Re-Installed Graphics Drivers
Re-Installed Latest Creative X-FI Drivers
Re-Installed Games, however still getting error.
Checked all Direct X Updates etc., currently running latest runtimes.
Completed Windows 7 Update, nothing relevant found.
Any Ideas would be greatful
Chris.
"Direct3DDevice:
Event ID: 1000
Level: Error
Keywords: Classic
User: N/A
Computer: Dyson-4
Description:
8.00 GB of DDR2 RAM
Chris.
