Hi guys
Is it possible to directly link 2 PCs with a crossover cable which are also on the same LAN as I am having a little trouble with bandwidth.
I am using OBS with NDi for a dual PC streaming setup. What I need to happen is for the Gaming PC to send the signal over the network to the gaming PC. But both PCs also need to reach the internet .
If I send 1080p across the LAN its about 150Megabits per second and if I downscale to 720p its 30Megabits per second. When I send 1080p the network becomes very saturated and basically nothing else from the gaming PC reaches the web. If I switch to 720p then its mostly fine except for ChromeCam which can’t seem to validate itself so has a watermark on the processed image. So I can manage but would rather be able to send the 1080p.
I looked at 10Gb ethernet but its too expensive at the moment, I also briefly looked a FiberChannel and some old FireWire solutions, but both are non-starters. In addition, I checked out Link Aggregation but its not supported by Windows 10. I see that bridging allows the second PC to see the first PCs internet (or vice versa) but this isn’t what I need.
I was wondering can the network be set up so that, both computers see everything on the Network as they do now except for they would see each other via a direct Ethernet connection between them using USB ethernet connections and CAT6?
My LAN is all GB Ethernet and all CAT6, (both computers connect to a switch and switch connects to the router).
I am aware I can buy a Capture Card instead but would prefer this NDi solution if I can.
