Directly shooting in to the sun issues.
16 Sep 2005
What used to be a UK
I recently spent two afternoons trying to perfect a shot of the sun "seeping through" a couple of Acers in a shaded area. The problem I had was one in which the excessive brightness blew the sky and silhouetted the foreground. I shot in raw and so was able to bring the foreground back but am still unable to do anything about the blown highlights. I tried using fast shutter speeds and ND filters but the improvement was almost insignificant. Is there anything else to try when shooting in situations like this? On this occasion I was unable to shoot with the sun behind me etc.
If you want the sun AND correctly exposed you will need fill light for the subject from either reflector or fill in flash.
I'd got no chance then as I wanted to retain some of the shadows
Overexposed sky and underexposed foreground.
Small aperture, stacked grads, meter as Raymond suggests and shooting as early or late as possible for the softest light would be how I'd try (I don't own a flash).
A combination of everything suggested above. I didn't have any stacked grads on me at the time which sucked and going later would have helped. Still I'll keep going back throughout the year.
