- 17 Dec 2010
- Northampton UK
Hi all....
When I play COD Black ops my pc uses DX9 and when I play MOH it uses DX11. Can I force Black ops to use DX11?
Thanks for any help.
Steve.
Steve.
Ok, well the game was coded using Directx 9 (presumably for easy porting from the xbox 360, and the fact that they're still using the same engine as so many earlier games iirc). So, unless they actually code a renderer to use the Directx 11 rendering pipeline, there's simply no way to force the directx 9 code to run with Directx 11. They're completely different.
, excellent design choice by MS
