DIRT 2 - 100% CPU load normal?
10 Dec 2004
Oxfordshire
as per the title, noticed this morning that i am getting stutters and the cpu is at 100% load all the time playing it, 4770's are at around 30-40% each
Normal?
I had an E8500 @4GHz and dirt 2 is one of the reasons I went for the i5. If i left task manager running, both cores used to be between 90-100% all the time I was playin dirt 2. With the i5 all 4 cores seem to use about 40-60%. The game is much better for it. It's a big difference
You can tell this game was primarily designed with the Xbox360, as it becomes much smoother when you have 3 cores or more.
On my dual core Phenom II 550 i average 40-45fps, turn on a 3rd core and it stays at a solid 60fps.
yeah that is my plan, trying to hunt down a Q6600 :).
as long as their is nothing wrong with the system then i am a happy boy for now
thanks for the replies and help guys
