- 5 Sep 2011
- Nottingham, UK
Hi, I sorted out my first DiRT3 problem last time which turned out to be simple, but I have another. I am not sure if it is hardware related or the game itself.
Basically, when the game is loading on this screen:
It seems to pause for around 2-3 seconds. It has always done this, but is now becoming very annoying when loading new races.
I use MSI AfterBurner Beta 7 to show FPS etc and the clock in the corner also pauses for around 2-3 seconds every time is loads.
Is this normal???
Thanks
My Specs:
AMD Athlon X4 640
Asrock M3N78D
Corsair DDR3 1333mhz 4GB
XFX HD5770 (Latest drivers)
CinderzFTW
Is this normal???
Thanks
My Specs:
AMD Athlon X4 640
Asrock M3N78D
CinderzFTW
