DIRT Demo Help
4 Sep 2005
London
Hey all
I've just downloaded this and extracted it, but whenever i run the instalation .exe it somehow thinks i'm trying to uninstall my wireless lan adaptor instead? It brings up a prompt box to remove my belkin wireless adaptor. This aint normal is it? :confused:
Any ideas?
well it thought mine was trying to run Epson Scan! Went into temp files and ran setup from there, installed it fine. Although I cant even load it up!
benjo said:
Ah got it working. Wasn't worth it though... what a pants game :confused:
Yeah, it's either a very early demo or it will be crap.
It runs very slow on my computer, even without AA and at 1280*1024 and that is with a heavily overclocked 8800GTS :confused:
Running nice and smooth here at 1680x1050 on a 320mb 8800GTS with everything on med-high just with shadows on low.
What do you consider smooth?
It runs at 40fps with or without AA and the only thing that gets the framerate up is to run at 1024*768 (which seems logical as 720p is the resolution the game runs at on the consoles propably)
you tried dropping the settings down from Ultra yet???
