DIRT
5 Aug 2006
Derbyshire
just installed dirt and the readme says:
Minimum Specifications
- Windows XP
- DirectX 9.0c
- Pentium 4 @ 3.0GHz or Athlon 64 3000+
- 1GB RAM.
- Graphics Card: GeForce 6800 / Radeon X1300 or above
- DirectX Compatible Sound Card
-*Dual Layer Compatible*DVD-ROM Drive
- 12.5 Gb Hard Drive Space
Recommended Specifications
- Windows XP/Vista.
- DirectX 9.0c
- Intel Core 2 Duo @ 2.66Ghz or Athlon X2 3800+
- 2GB RAM.
- Graphics Card: GeForce 8800 or Radeon X1950
- Sound Card: Creative Sound Blaster X-Fi Sound Card.
- Dual Layer Compatible*DVD-ROM Drive
WTF how can a c2d @ 2.66 be the same as a 3800+?!
i thought my e6600 was fast :confused:
I think they're just trying not to be biased towards AMD/Intel/nVidia - you might find the packaging was made before the 2900 came out
