20 Mar 2009 at 16:55 #1 Django x2 Django x2 Soldato Joined 28 Sep 2008 Posts 14,184 Location Britain So a SQL 2K5 uninstall has gone bad and left instances all over the place. Is there a way to remove all traces of SQL from the box with some 3rd part apps or other? Thanks
20 Mar 2009 at 17:38 #2 iaind iaind Soldato Joined 26 Feb 2009 Posts 14,817 Location Exeter You could try a repair install from the source then try the uninstall again. Might just be easier to stop/terminate the processes and remove them. Then remove the files and registry entries by hand
