Disable CSM issues on boot
30 Jul 2007
Lincolnshire
Hi guys,
So thought my ROG Maximus VI Hero board was slow to boot, a lot slower than it should be. Found a load of tips e.g. Turn off smart testing on drives, disable CSM or set to UEFI only if on UEFI install of W10 (which I am) etc.
So I've done this and now I can't boot... after disabling CSM I get an error "the current BIOS setting do not fully support the boot device" or similar and mentions CSM.
I set it to UEFI only and it says no os found... I turn it back to enabled and it's the same thing. Now I know resetting jumper will revert and maybe sort it. But I want to get the right CSM settings... any ideas guys?
Boot drive is 850 evo 500gb. GPU is 970.
