- 22 Sep 2010
- Torbay
I've just completed a rebuild using RGB components and have gone for a different colour scheme.
My case is a Silverstone FT02 and I have 3 FN181-BL fans at the bottom but I no longer want the blue LEDs.
Rather than buy 3 non led versions is there a particular cable I can cut that will disable them?
Thanks
Thanks
