Disable GPU RGB permanently
18 Oct 2011
Wondering if anyone knows a way to disable GPU RGB permanently? Not really wanting another program running constantly just to disable RGB, i saw RGB Fusion 2.0 can disable the lights but not sure if it works once the program is uninstalled.
You could just unplug it on the card, probably will require some minor dissassembly or you might be able to get at it without depending on the model.
Most of them do as I've set my rgb to white and when the program was uninstalled it stayed white.
OK nice to know, really do not want RGB Fusion on my machine.
Which card is it ? Some are easy to unplug if the header is on the open part of the heatsink or on the bottom or top of the heatsink on the pcb, so no need to open the card up. Depends on card.
Gigabyte gaming oc 6900 xt
