This is my situation my TV has 3 HDMI ports yet I have 4 HDMI devices.
I use an auto HDMI switch so that I can have up to 3 HDMI devices plugged into a single port and the one that is on is made active and the others are isolated to prevent feedback.
I currently have my Blu-Ray and my Xbox360 on the switch since they would never be turned on at the same time.
Now my issue.
I want to run a 5m HDMI cable from my PC to the TV so that using a wireless controller I can play PC games and output them to the big screen of the TV.
The problem is though that since my PC is on most of the time I feel it would seize control of the auto switch and prevent the other devices being able to switch it.
I do not want to have to keep unplugging cables and I have not bought the 5m HDMI cable yet.
So before I waste money on a cable can anyone tell me if it is possible to disable the HDMI port on the GPU so it's effectively turned off and the switch will work right?
Now my issue.
