- 17 Mar 2011
- Snowdonia
I recently bought a Seagate Barracuda 2TB ST2000DM008 from ocuk which is working fine but it often makes an irritating noise which I believe is head parking.
I can stop this by disabling APM (advanced power management) using CrystalDiskInfo, but it reverts to default setting on system reboot.
Is there a way to permanently disable APM and the annoying head parking? The noise is bad enough but I also worry about reliability of the drive over time.
Thanks
Thanks
