Hi
I have just purchased the HIS ATi RADEON 9250 (128 MB) AGP Graphic Card for my PB imedia 1307. Before installing it i need a little help, has informed in my previous post here
http://forum.packardbell.com/en/viewtopic.php?t=54005
i will need to disable the onboard graphics i have on my pc. I have gone into Bios set up and here’s what i found,
Bios setup
Advanced
CHIPSET THEN ENTER, THEN I HAVE
NORTHBRIDGE SIS66FX CONFIGURATION
SOUTHBRIDGE Sis964 CONFIGURATION
When i enter NORTHBRIDGE SIS66FX CONFIGURATION i get 4 settings 1st is
PRIMARY GRAPHICS ADAPTOR WHICH SET TO (PCI) IF ENTERED SHOWS PCI, AGP, ONBOARD AGP
GRAPHICS WINSIZE WHICH IS SET TO (64MB) IF ENTERED SHOWS 32MB, 64MB, 128MB
AGP FAST WRITE CONTROL WHICH IS SET TO (DISABLED) IF ENTERED SHOWS DISABLED AND ENABLE
SHARE MEMORY SIZE WHICH IS SET TO (64MB) IF ENTERED SHOWS 32MB, 64MB, 128MB
Please could you tell me which setting i have to select to disable onboard graphics? One more thing if my pc is using onboard graphics why is PRIMARY GRAPHICS ADAPTOR SET TO (PCI)?
Any help would be great. p.s. be gentle i am no pc expert. Thanks, Steve
Bios setup
Advanced
