Disabling Optimus - any problems?
ajf
ajf
30 Oct 2006
Worcestershire, UK
If I disable Optimus in the BIOS are there likely to be any problems?
There are several laptops at work which have been blue screening with video driver problems. So far we have been unable to determine the exact cause.
However on one laptop I have disabled Optimus to force the laptop to only use the Nvidia card.
Since I did this there have been no further problems with that particular laptop.
Before I go and do it on any of the others I just wanted to check it is not going to then cause further, and bigger, problems!
This is a last resort as the machines have been formatted, drivers updated, even parts replaced and the problem still persists.
