I built a little mini ITX system a while back consisting of a Zotac 9300 ITX board and an Intel Celeron E3200 dual core processor, the little rig has been running absolutely fine for a good while until a week or 2 ago it decided it would no longer load the OS. It would get stuck at a point just after posting saying “verifying dmi pool data……” or something along those lines.
I managed to finally sort it by going into the bios and loading the safe default settings for the motherboard (resetting the bios oddly didn't help), unfortunately the OS was garbage so I had to reinstall the OS. Its taken me a few days after installing the OS and putting all my programs back on to notice today that XP can only see one core (both in device manager and in task manager).
I thought ok XP can be funny with dual cores so I quickly loaded CPU-Z up and to my surprise it shows this dual core operating with only 1 core and 1 thread!
I’ve reset the CMOS a couple of times but to be honest I’m not sure how I would go about trying to enable the second core again, as Ive never had to with any other rig other than an old pre SP2 XP system that needed an AMD dual core patch to correctly run an old X2 athlon.
I have cpu-z screenies of this chip running on this board with both cores enabled so its not like its a compatibility issue Ive never picked up on. I’ve not flashed the bios or changed any hardware. The system has been running stock and rock stable for a good few months until it had that nasty OS loading issue a week ago.
I have a feeling the “verifying dmi pool data……” could have been the motherboard trying to recover from a catastrophic hardware failure and now the pc is limping along on one core.
Anyone know what could be up??
