I'm running Ubuntu 9.10 on an old Toshiba Satellite A30, and it's been fine until now, as now when it logs in there's no cursor! I have to blindly open Applications, open a Terminal window, and type;
and wave the mouse around to get it back, but it only lasts until I end the session. Next time I turn it on, same issue occurs. Through some research, it seems this problem crops up all the way back to 6.10?
Another issue, though only a minor one, is the machine won't shut down properly. It gets to 'System Halted' and stays there, on. I have to manually power it down.
I couldn't install Ubuntu on it normally either, as the machine suffers from some bizarre issue where I have to hold down a key for it to do anything. To install the system, I used a 9.10 alternative CD in Expert mode, with all the additional options enabled, apart from 'only free software'.
Code:
update-icon-caches /usr/share/icons
