Hey guys!
I recently upgraded my PC about 2 weeks ago and am having some problems which I'm scared and very disappointed with because I spent a lot of money!
PC Specs:-
Asrock Z68 Pro 3
Antec True Power 650W PSU
Went from a 560Ti to a 780
2500K CPU @ Stock
Mount Doom CPU Cooler
Team Vulcan Orange 2*4GB RAM @ 2133Mhz
Went from a Zalman z9 to a Coolermastrer CM690 Advanced II
Added an SSD - 250GB Samsung Evo
Replaced HDD for 2TB Seagate Barrucuda
1 - My PC will not take the XMP profile in bios and will just restart and turn on/off approximately 3 times. To make matters even worse it will do this if I change it to even only 1600Mhz and increasing the timings slightly. I've tried everything, my PC won't accept anything but 1333Mhz with 9-9-9-24 (default). I've triple checked my mobo manual and it does say that it can handle 2133Mhz. But surely it can handle 1600Mhz anyway. :/
2 - I was ready to play some Borderlands 2 earlier this week and have noticed this electrical buzz. I've done some research and have found out maybe it's coil whine. However when they all talk about coil whine, it's a high pitched one. The noise that I'm having is at a lower pitched sound (electrical?). I've tried to exactly pinpoint the problem but cannot as the PSU and GPU are too close together (really hard even with a rolled up piece of card). All I can say is that this is the first time this problem has occurred. I didn't have any of this with my 560Ti. I'm unable to test the components either as I gave my GPU to a friend who has unfortunately moved away now due to unforeseen circumstances.
This buzz only really occurs under load - tabbed into Games/Heaven Benchmark. It also changes as I change my view onscreen. I recorded this while being tabbed out of the game, tabbed in, moved the mouse about a bit then tabbed out. Apologies for the hoover sound, I used a yeti to record this and it had to be pretty close to catch it well.
http://picosong.com/YXtH/
PS - My Cooler-master case did not come with the VGA card holder which is shown in the manual, in the contents of the box. Currently my 780 is only being supported by the PCIe slot and one small random screw.
I would really really really appreciate some help and advice. This has put a downer on my pc building experience. D:
Sorry for the long post, thank you very much!
Kind regards,
Qwenty.
PC Specs:-
Asrock Z68 Pro 3
2500K CPU @ Stock
Kind regards,
Qwenty.
Running awesome on borderlands now. Could only tell it was there if you properly listened. Compared to as soon as someone would step in my room, you would automatically notice it. xD
