Disaster Strikes - Fahrenheit
26 Dec 2005
Paisley
I got this today off the MM forums, but the thing refuses to install on vista, saying its been interupted.
Does anyone know if there is a workaround (without installing a copy of XP).
Sorry, I can only echo and repeat the issue, i'll have a little look for a fix.
EDIT:
http://www.iexbeta.com/wiki/index.php/Windows_Vista_Software_Compatibility_List
States “Fahrenheit - The installer starts but keeps saying that installation has been cancelled. The game itself does work if previously installed under XP and run from Vista.”
So, try installing it to a computer that has XP, then doing a direct copy of the install directory? It’s worth a shot, I’m going to give it a go.
