Disco Ball
21 Jul 2004
Harrow, UK
I just bought a Disco Ball off eBay, and I think the bulb inside is not bright enough.
Its a 12V 5W small screw cap bulb, and was just wondering where the best place to buy a brighter bulb is... or is it even possible?
it might not be able to handle a bigger bulb!
there should be a lable somewhere on the wire telling you the maximum
Well the supply can only give 6W max, so really a 5W bulb is the max you can go unless you get a new power supply.
I think he's talking about one of the Gadgetshop style ones. Black plastic with "windows" of different coloured see throughish plastic and a bulb inside. It spins round and projects the different colours disco ball style.
do you mean this? :D
