Discoloured tile grout
Commissario
18 Oct 2002
Down under mate!
Hi gents the tile grout in my shower has started to discolour quite badly. Is it worth me trying a grout pen or is there a specific cleaner I can buy and use.
What colour is it? Maybe worth squirting it with undiluted bleach and leave for a while...may bring off the stains.
It's a yellowish colour. Apparently shampoo and showgel discolour the grout overtime.:confused:
Will give the bleach ago.
You can use white spirit vinegar or something like vanish oxy powder, both will whiten the grout (assuming its white).
Vinegar is ok to use on ceramic tiles but if you have natural ones like marble use the bleach powder.
Could try Blue Magic or Shadazzle, if the shopping channels are a true representation of the products either should bring them up as good as new :D
undiluted thick bleach on an old toothbrush + some elbow grease and it should sort it. Mine was really bad and ended up looking like new after.
Have you tried steam cleaning?
We have tiled floors downstairs as well as our bathroom and it works wonders.
Yeah the bleach seems to do the trick. I will go out and buy a firm toothbrush and give that a go.
I found a toothbrush was the perfect size to work into the grout channel. An electric toothbrush would be even better :p.
Cillit Bang Black Mould Remover , just spray it on rinse off with the shower head tens mins later amazing stuff no scrubbing needed
