- 10 Sep 2010
- Cornwall, England
Hey guys
I'll start with the weird problem... everytime I reboot my PC I don't have internet, to gain internet connection I have to go to Control Panel > Network and Internet > Network Connections, Then I have to disable the port that has the ethernet cable in, take the ethernet cable out of the port I just disabled and plug it into the other port, Then enable the port the cable is in and I'll then have internet.
If I reboot I'll loose internet connection and have to repeat the above process, happen's with either ports. Issue started happening when I moved my PC to my Brother's house for a LAN session.
Any idea's guys?
Ok, onto the second problem, that may or may not be related to the first.
I have xbox live ( Just for halo 3) ever since I got the xbox I've had a problem where I'll get diconnected from XBL, usually after every game (every 12 minutes), but sometimes happens when I'm in-game. Also sending messages doesnt work (XBL says it cannot perform this action), also the xbox dashboard takes ages to load.
My NAT is Open and I have forwarded ports 3074 and 88, Tried wired and wirerless, same issue.
Also when I get disconnected from XBL the entire internet drops out for a few seconds.
Very annoying
Any help guys? Thank you!
Any idea's guys?
Very annoying
