Discord/Razer mouse issue...
30 Dec 2003
Bigger box!
So... I have a Razer Viper Ultimate mouse. The button layout is that the thumb button closest to me is 'mouse 4', and the thumb button furthest from me is 'mouse 3'.
Windows recognises them as Mouse 3 and Mouse 4 respectively, no problem.
In Discord, Mouse 4 is set as PTT. In Discord keybinds it shows that Discord recognises a difference between 'mouse 3' and 'mouse 4' no problem.
However, whether I press 'mouse 3' or 'mouse 4', Discord treats them both as PTT. Not the end of the world, granted, but in PUBG 'map' is set to 'mouse 3', and every time I look at the map it activates PTT.
It's driving me nuts. Any ideas??
Doing a quick google, it seems like this is a bit of a known issue with Discord unfortunately. It seems to suggest they incorporated a fix for it some time back, but it may be they have accidentally broken it again. Maybe worth logging a ticket with Discord.
Good effort from Discord actually...
I e-mailed their support team and received the following...
Hey Chris,
Thanks for reaching out to us together with all of that information!
Sorry for the inconvenience on the other hand regarding your keybind control using your Razer mouse.
I just got a word regarding this issue from the team that they released a fix on the Public Test Build client. Would you mind giving it a shot if it works for you? You can download that here: https://discordapp.com/api/download/ptb?platform=win
If that didn't work, could you try the Canary version instead? Here's a link for that: https://discordapp.com/api/download/canary?platform=win
I sadly do not have an ETA on when the fix will be officially released on the stable build but I'll let you know asap once I get an update!
I apologize for the inconvenience once more but please feel free to update me if you got any questions or if I can help you with anything else in the meantime!
Best regards,
Russell
Tried the test build, and it works a treat.
Ha, nice! I just got this mouse the other day. Previously had the G Pro wireless but the double click issue with it plagued 3 of them so gave up RMA'ing. Good to know regarding Discord as I normally use alt but that's also for ingame items.
It’s an awesome mouse. How are you finding it?
Battery life is really good too. Plus, with a motherboard that has always on USB power (probably anything from the last few years??) it means that as long as I remember to dock the mouse after use at least one time in a few days, it’s always good to go!
I'm really liking it, the battery is similar to the G Pro at this point, but I really like the dock, I've not charged since I bought and charged it the first night. I like the RGB on the bottom to indicate a rough battery level. It's currently orange so it will need to be charged soon. The ONLY thing I don't like, is it doesn't launch the profiles until the software is opened and also the mouse is a bit slower to 'activate' from sleep than the G Pro.
Yeah, the software does take a little while...
Ruins the ‘minimalist vibe’ I’m going for when everything flashes and cycles colours for 30 seconds every time I boot
