Disk Boot Failure on NT4 , help please
28 Sep 2003
London
i have a pc that i took the hard drive out of to put in to an external USB case to try to get the data, but when i plugged it in it did not recognize the drive in windows.
so i put it back and now im getting "disk boot failure please insert system disk"
It has NT4 on it, do i have to boot from NT4 boot disks or will any boot disk do?
is the data still likely to be there ?
thanks..
Have you checked that the BIOS boot order hasn't changed?
yes. its recognizing the HD just not booting from it.. and its the first device to boot from
I dont have any floppy discs either, to try to download a boot disc.
ill have to go out later and buy some just to try it with.
