31 Aug 2012 at 14:32 #1 TheHitMan-1973 TheHitMan-1973 Permabanned Joined 2 Feb 2010 Posts 1,447 Location Haywards Heath Why is my disk clean up taking so long
31 Aug 2012 at 14:58 #2 Uhtred Uhtred Soldato Joined 18 Oct 2002 Posts 6,372 Location Bedfordshire XP? There's a reg tweak you can do to speed it up
31 Aug 2012 at 18:41 #3 TheHitMan-1973 TheHitMan-1973 Permabanned OP Joined 2 Feb 2010 Posts 1,447 Location Haywards Heath Uhtred said: XP? There's a reg tweak you can do to speed it up Click to expand... Windows 7 Prem
1 Sep 2012 at 00:57 #4 bledd bledd Don Joined 21 Oct 2002 Posts 46,868 Location Parts Unknown Install Ccleaner instead, it's freeware and does a far more thorough job. Check the options before you do a clean, by default it can remove your saved browser passwords / history. Awesome tool, have been using it for about 8 years
