Disk I/O is more than 500
17 Apr 2012
Hey
Hoping for some advice. I have just ran the Performance Monitor on my PC, i've never used this before. Everything seems fine, only thing that looked like there may be concern is the Disk Performance saying "Disk I/O is more than 500 (read/write) per second on disk 1", here is the screenshot:
Is this something I should be concerned about?
Thanks in advance
I would run the manufacturers software on the drive and see if you can do a smart test on it or health check on the drive.
