Diskeeper 2010 Home Advice?
Is this bit of software worth the money?
No, definitely not. Apart from the fact that there are better payware defraggers about, diskeeper corporation are scientologist clowns.
If you want a 3rd party defragger, try the freeware Mydefrag.
Is this bit of software worth the money? Ive never used anything like this before:confused:, so would like to know your views.
Cheers
Using 2010 professional, and does what it claims on the tin: fully auto, defrags system files, prevents most of the fragmentation, optimizes file placement etc. Excellent disk maintenance utility and is 'set and forget'...can't really ask for much more from a defragger.:cool:
