Display Blur
23 Feb 2009
Huddersfield
Hi All,
Recently i've been having an issue where there's a blur/shadow on all of my PC displays - any ideas how it can be solved?
Sam
Hi, any chance you could post a link to a screenshot like that one but at your full desktop resolution and saved as .PNG? It's difficult to tell what you're talking about with a downscaled, poorly JPEG compressed image.
Hi,
I'm now on my laptop, and can't see the blurs on the screenshot, so it must be a display problem - maybe i'll try another monitor - strange as it works fine with the Xbox/TV.
In that case, it's likely you're running your monitor at the wrong resolution (ie. not the native resolution).
What monitor do you have, what resolution are you running it at, and are you using DVI/HDMI/VGA to connect?
