- 1 Apr 2012
- Nottingham, UK
Hi,
Recently I have noticed that when playing games my screen will either go black and quit to desktop and I get a message saying "Display driver stopped responding and has recovered", my game then quits. It has happened in BF3, Skyrim, Saints Row 3 and Minecraft.
My specs...
AMD Phenom II X6 1090t @ 3.2GHz (was 3.6 but put back to stock to rule out)
Asus Sabertooth 990FX
8GB Corsair Vengeance 1866MHz @ 1600MHz (Underclocked to rule out)
MSI Twin FrozR III 6950 2GB @ reference speeds
Crucial M4 128GB
Asus Axe Square Gold CPU Cooler
Antec 1100
CoolerMaster GX750
Windows 7 Professional (64-Bit)
Catalyst 12.3
At first I thought this could be due to overheating so I installed HWMonitor and the highest logged temperature was 61 C. Not hot enough for my card to be failing due to heat. I don't think my PSU is at fault as 750W is definitely high enough for my system specs and using HWMonitor all of my voltages are stable when gaming or otherwise. My CPU gets to about 42 C on max load so that isn't overheating.
Next I thought it was a driver issue so I have upgraded from the ones supplied with my video card CD to the latest, which at the time was 12.3, and I still have issues. I then updated to 12.4 and the same thing again. Win 7 is set for display to never go to sleep and I have changed the registry value per the microsoft article for GPU timeout.
The problem is very intermittent, sometimes I can be gaming for hours and other times it does it 10 minutes in. It seems like a software issue but I don't know where to start.
Has anyone experienced this and/or resolved the issue? Any help would be highly appreciated
Thanks,
Jordan
My specs...
Crucial M4 128GB
Antec 1100
CoolerMaster GX750
Catalyst 12.3
Thanks,
Jordan
