Display fuzzy using Dvi..
24 Dec 2004
Telford
I have a Samsung B2420h 24" Monitor and for some reason since re-loading windows my display seems very fuzzy. I,m using the same ATI drivers as before on my 4850 but now @ the native res of 1080p it all seems a bit fuzzy. I,m finding text hard to read and its actually hurting my head looking at the screen. Its connected using a DVI to DVI cable.
Before re-loading windows it was fine so i,m guessing there must be a setting or something ??
Any help would be much appreciated..
Cheers
Cleartype shouldn't cause fuzzyness. In the CCC, under 'pixel format', It should be set to 'RGB (Full RGB)'. Try that and enable clear type again and see if there is still fuzzyness
I cannot find and option called Pixel format or a setting to set to FULL RGB..
Where abouts are these ?
I do seem to have quite a few options missing in CCC. I,m sure before i could change the overscan options etc... I dont have that option now. ?
Cheers
To get to those, Open the CCC, then go to 'desktop & displays'. At the bottom where it says 'please select a display', right-click the monitor (the bottom one) and click 'configure'. The overscan option is under the 'scaling options' tab (should be at 0%) and the 'pixel format' tab is where you find the pixel format (should be 'Full RGB')
I dont have that tab. Have tried re-installing drivers but for some reason i cannot get those options .... ?
Screen grab of what i have
