Hi all, new to the forums after I ran out of ideas on what to do and need some advice. Apologies if this is posted in the wrong section.
Today I decided to clean-up a 12 years old laptop that has never been opened. The laptop in question is a Asus ROG 750JH.
CPU Package temperatures used to be in the 60s while idle, and even shot up to 94C if opening Chrome on 10+ tabs. Could hear the fan spinning loud so figured it might be time for a cleaning.
I first disassembled the laptop down to the fans which had a blanket of dust inside covering the fins. I cleaned these thoroughly and whiel I was at it I decided to also change the thermal paste on the CPU and GPU. I then stripped down all cables/connectors and took apart the motherboard. I managed to replace the paste on the CPU but the GPU heatsink wasn't budging so I decided to leave it be as I was afraid not to break something. I then assembled everything back together and when I plugged it in it would only turn on for half a second, could see the LEDs turn on, fan spin and then it would go off. So I thought it might be a connector issue. I took the laptop apart again up until the keyboard/motherboard. Disconnected all RAM boards and connectors and connected everything back. I then put the keyboard back, connected the plug and turned it on. The laptop turned on fine without issues, Windows loaded, ran some test in HWiNFO and was happy to see temperaturs drop in the 40s while idle and climb to 64C while browsing in multiple tabs. So I decided to turn it off in order to assemble it. When turning it off it asked if to update windows and I let it run the updates. I walked away and when I returned a couple of minutes later, I could hear the fan spinning lightly and see keyboard backlight on but nothing on the screen. Left it like that for a while and seeing how nothing was happening, I force turn it off from the button. Turned it back on and the screen then wouldn't come on. I turned it off again and took it in my office to connect the external screens and to my surprise the external screens would work fine but the laptop screen wouldn't come on.
I have no idea what happened. It originally worked after the cleanup and then after the shutdown/windows update it stopped working. I haven't moved it between the working-not working phase so no clue what happened. I tried reconnect all the wires running from the screen to the motherboard and nothing. Within windows on the display settings it detects both external screens but not the laptop one.
What can I do to troubleshoot it? At this point I am just happy it works as it's the first time I take a laptop apart like this and I will settle with using just the external screens, but if anyone has any suggestions I would appreciate it before I assemble it back.
Thank you in advance
