Display / Monitor Program
4 Mar 2007
North West
I am after a program similar to NVIDIA Control Panel which I can use to switch between my normal monitor and my LCD TV. I dont like the windows one and for some reason NVIDIA doesn always work i.e you would change the displays round and it would just flicker both screens and then just go back to the way it was lol - any ideas an that aswell???
Oh and it needs to work with Vista.
Ta
Ad
Doubt you're going to find anything, i have the same vista problem, its the NVIDIA drivers and control panel that are just tosh. I've set up profiles and saved them in the control panel and just wait for windows to fart about for about 5 mins when i plug something in, and instead of correcting resolution refresh and which is primary etc... i load the "Laptop & TV" profile. It still takes about 5 mins to plug another monitor/tv in but its better than i was before. Little things like this annoy the heck out of me, its no vista's fault but its because i'm running vista and the manufacturers are generally uselss... Makes me want to go back to XP but its just too much hassle and i'd probably notice the little things that vista is better at, you can't win :p
