Display Nits quick way to tell what your running at?
9 Dec 2006
@ManCave
Is their a nice way to tell how many Nits your screen can handle? or current running at? without third party equipment
For example using a S271DS at the moment, the Max Nits they suggest from reviews is 350Nits. if I wanted to say compare that againist new OLed offerings can i for example work out the % of Brightness i'm using vs 350Nits & do rough calculation of normal operating nits?
eg 350nits / 60% brightness = x nits
then i could match the lowest nits from OLED screen to my screen & see if its good enough?
That would only work if the 0% brightness setting was basically 0 nits if super dark, and if it’s a linear relationship between the brightness control and actual luminance output.
If you can confirm how dark 0% is on that screen then for your purposes of trying to get a feel here, it’s probably a reasonably close approach
