Display port adapters
29 Aug 2010
United Kingdom
Hi guys,
So I need at least two Display port adapters, one for my 6850 and another for a 5570, My question is,
I know you need an ACTIVE display port adapter for DVI like one of these:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-057-HS&groupid=701&catid=1915&subcat=1577
But I need to be using HDMI rather than DVI, A) because I need sound and DVI doesn't do sound, and B) because I have lots of HDMI cables.
My question really is, Does a Displayport to HDMI adapter need to be "active", and will it still transport sound?
Thanks!
looking for an active dp to hdmi but they all seem to be passive for some reason
you could get a standard dp to dvi ( startech , xfx , sapphire ) then use a dvi to hdmi but I don't know if the sound would still go through.
DVI doesn't do sound =/
I've only found 1 active and its £70 which is just stupid money for a little adapter.
It can be had for £30-£40, £70 is just re-brand markup.
I have the Sapphire branded £70 version and the BizLink version for a friend that set me back £35 and they are exactly the same.
And DVI does do sound as i have it connected to my KURO DVI-HDMI, jut make sure your using the DVI port that does have sound.
And DVI does do sound as i have it comment to my KURO DVI-HDMI.
Im talking about the Startech DP to HDMI adapter. I can't seem to find a Bizlink Displayport to HDMI adapter, what should I search for in Google?
If you are talking about the: Sapphire 44000-02-40R Active Display Port DVI Cable, You can get it for 15 quid.
Yes that's ones a ripoff.
You can go DP-DVI Active Adaptor then DVI-HDMI AMD adapter i would Imagine.
Dell BizLink DisplayPort to DVI-D Dual Link Adapter , ACTIVE , Powered by USB Port , Brand NEW , Dell P/N : XT625
