Display port issue
21 Jan 2012
Hereford, UK
Hey guys so I just brought a 1440p 27" monitor been using hdmi but just changed it to display port as I found cheap one in black Friday in my local computer store.
anyways the screen keeps going black while gaming for a split second then fine again randomly happens
I have r9 390 overclocked
On windows 10
Latest drivers
if that helps, works fine on hdmi and dvi
Any help appreciated as I'm new to display port
I have a similar issue.
I purchased the Sapphire Nitro R9 390 and the iiyama Prolite B2783QSU 1440p from here.
I keep getting random split second second blank screens.
I am yet to try connecting via HDMI/DVI, but I got this combo for freesync, which by all accounts needs to run on displayport.
I have tried the different DP ports on the card and it still happens, the DP cable that came with the monitor doesn't work, so I am using an old one. I have a new DP cable coming to check that.
Current setup is Windows 7 - i7 3770K, 32GB RAM, HX-750 PSU.
I'm running the Crimson 15.11.1 drivers.
I swap a Samsung monitor every day at work from another desk to my desk as I like it. A couple of times I have come across the same kind of issue where I will get random one to thirty second black out's. Turns out if I just reseat the HDMI cable on the monitor the rare time it happens it will stop. Seems to be a bad contact.
