Hi all
Just been looking at 22" monitors on OcUK but noticed none of them have DP connections. If you need a monitor with a DP to be able to use triple display eyefinity how come there isnt any on there.
I will be buying another 22" monitor next month for dual display and will buy another one the month after that.
So should i try and find a 22" from somewhere else with a DP or should i just use a DPtoVGA converter or DPtoDVI converter?
Also Can you use 2 DVI and 1 HDMI connections for eyefinity i.e. one DVI converted from DP?
