Display port to HDMI is OK?
19 Nov 2015
Glasgow Area
Hi, I have 3 HDMI screens connected to my PC. (2 monitors and 1 TV).
I don't use them all at the same time, the TV is our regular TV and just use it fr watching Blurays from the PC.
Anyway....
I am looking at a new Graphics card and it only has 1 DVI and 1 HDMI connector at the back, the rest are display ports. Am I OK using an inexpensive adapter to plug an HDMI cable into the DisplayPort on the GPU? I think I will be but no first hand experience so just checking.
They are both digital signals so there should be no loss in quality.
I have also just read some reviews and everyone else is saying the same that it should be fine. I think display port gets rid of the risk of running into HDCP protected devices seems as many people use them as home theater systems.
I have a display port to DVI and i see no problems with them
Thank you. Sounds good.
